Builtiing a Car subwoofer for home use.
Username: Azndragonz
what is the best brand for a subwoofer?, i heard rockford fosgate and jbl was good, i see some for close or around to $100 and What is the best type of enclosure for a Subwoofer ??
Username: Edison
Post Number: 87
You can order something like this:
http://www.bestbuy.com/site/olspage.jsp?id=1051384114546&skuId=5434826&type=prod uct
You can buy this sony sa-wm200 already made with an amp built in - sounds good for less than $100 for home use.
http://www.etronics.com/product.asp?stk_code=sonsawm200&rpc=4192&catid=4197&stor e=
Username: Saku
Post Number: 7
hey Ty,
im also making a pair of car subs for home use. i just want to know what kind of amp your getting for it. cause i want a cheap amp for my subs
colby
Post Number: 7
This is the cheapest one I can find, and the most watt avaiable for the price, Its an Dj amp, 134.99 + Shipping, thats dirty cheap, If I had 300 buck i would built my subs and get that amp aready !!!
http://www.etronics.com/product.asp?stk_code=pylpzr600&svbname=16
Username: Saku
Post Number: 9
hey thanks ty,
iv been looking for and amp like that for a week now and i havent found one untill now. thats like a perfect amp for me.
thanks again
colby
Post Number: 8
YAH, why dont u give me the left over money anyways,
Hey I have two 12" kenwood subs in my car and I was hoping to get a DJ amp or power converter or something so that I can hook them up in my house, will this amp do it? Whats the whole process to hooking them up (wiring...) Thanks a lot, Ethan
Username: Smorlan
Home audio and car audio don't mix. Totally differt design, acoustically speaking .You won't be able to build an accurate sub with a car woffer/driver. Its built for pure spl's not accurate bass. Just goes boom!!!!!! very loud in a small space. If you want to build your own go to parts express or madison sound. They will point you in the right direction. Driver and amp wise that is> Good luck DYI'ers.
Better yet just buy a SV SUB OR HSU. BETTER BANG FOR THE BUCK!AND ACURRATE TO.
Username: Smorlan
YA, I SAID ACCURATE (OOPS)
