New member Username: BobiranPost Number: 1 Registered: 12-2003 | Hi, planning to buy a Rotel RCD-02 cd player and a RA-02 integrated amp with B&W DM602 s3 speakers. the room is 5x7 meters. I don't know if it is adequate for this large room. By the way, how do you find this set? any suggestions? |
New member Username: EdisonPost Number: 96 Registered: 12-2003 | Where are you located? If in England, http://www.weymouthhifi.co.uk/website/rotel-ra02.html If in US, look for a dealer in this sight : http://www.rotel.com/dealers/index.htm Should sound pretty good. Get good cables like Ixos 6003 speaker cable, and gamma RCA at: www.vertigoonline.com Rotels also sound good with a more refined sounding speakers, but if you like the way them with 602, go with it. You might want to hear them with paradigm speakers. Check out this sight for more speaker recommendations : http://www.hifichoice.co.uk/buyersguide_list.asp?category=SPK&subcategory=LSPKS |
New member Username: ArnoldPost Number: 1 Registered: 12-2003 | Hi Barmak I have RA-02 and the 602's and they pretty much fill up my room ( 5X5m) but it depends on what music you listen to... For small recordings like heavy acoustic sets... Jazz trios and quartets which i listen to they are great! audition them with your music and see if they are to your taste. p.s. I still didn't buy the RCD 02 .... i have not decided whether to by that or the Arcam 72... |
New member Username: EdisonPost Number: 100 Registered: 12-2003 | I liked the arcam better. |
