My receiver provides a couple of different settings for the subwoofer. I can have it direct everything below the cut-off to the sub, or I can have it send to the sub in addition to my main speakers.
Which would you recommend? Would I be better off to have the receiver send everything below the cut-off to the sub-woofer? Or should I send to both, and use the sub's variable high-cut filter to try to blend it with my mains?
Thanks in advance!
Derek
Whats the BEST box set up for one 10",1100 watt,bridged sony explod sub,with a 600 watt kenwood.In a hatchback? enclosed or exposed, with or without vent tubes??? And should i add a capasitor?
