Bronze Member Username: SgtpeperColorado Post Number: 79 Registered: Dec-03 | Okay I just bought a new tv and moved so I have a lot of things that needed to be hooked up. Heres the list of compnents and connections. TV: Loewe Articos 30" The TV has one true component input on the back but also came with a VGA connection cord that converts to component. So I basically have 2 component inputs on the back of the TV Reciever: Pioneer Elite 45tx Has one component output and 2 component inputs Plus a enough optical and coax for sound Cable Box: HD Motorola unit from Comcast Component to connect to my system And I think this box only has optical for audio no coax? DVD Player: Pioneer Elite 47ai Component out Coax for audio PS2: Component out Optical audio Computer: I have my computer hooked up via USB from my computer to my receiver for audio The way I have it hooked up now: Currently I have the system hooked up so that the PS2 and the cable box go through the reciever to the tv. Then there is a component connection from the reciever to the tv. Digital audio is hooked up through the reciever as well. I then have the DVD player hooked up through component through the vga adaptor directly to the tv and the digital audio to the reciever. Im really not sure how good of quality the included vga to comonent adaptor is which has me wondering but I cant even think up any other way to hook all these things up. Also with the computer hooked up to the receiver I now can ONLY use the reciever for sound. I can NOT use the speakers connected to the computer. Not sure why that is? Any and all help with my ramblings is greatly appreciated. Thanks Jeff |
Bronze Member Username: SgtpeperColorado Post Number: 80 Registered: Dec-03 | bump? |
Bronze Member Username: Kyle___bergPost Number: 27 Registered: Jun-04 | http://www.monstercable.com/hookup_learning/csg/ http://www.monstercable.com/hookup/pdf/PS2_hookup_outlined.pdf try them they'll help |
