Urgent Amp Question
Username: Phoenix1397
Post Number: 7
I've recently got a couple of Gemini speakers (8ohm, 160W each) and a Gemini amp (xg2001 1000w, stereo 4-8ohm, mono bridged 8ohm min.)
I also have one 200w EV speaker, my problem is I don't know how to exactly wire the 3 speakers to maximize my spl.
My amp has got 8 connections, 4 red, 4 black. In two rows marked A and B.
A quick reply would be great cos I got to get these to work soon.
Thanks
Username: Edison
Glendale, CA US
Post Number: 516
Connect the Gemini speakers to the row marked A, and connect the EV to the B (one only).
Now you can choose which row to play - some amps allow you to play the 2 rows simultaneously by pressing both A and B (if there are buttons).
Post Number: 8
Does it matter about the + and -, when I connect the three speakers?
Thanks
Post Number: 9
Does it matter what way I connect the wires, i.e. + and - with the 3 speakers?
Thanks
Username: Soccer
Post Number: 302
YES! (+) on the amp should connect to (+) on speaker, and (-) on amp should connect to (-) on speaker. The speaker wires are usually marked
Post Number: 10
I'm aware of this setup, but the cable is unmarked on the amp side, just stripped bare?? And the other end of the cable has a plug for the speaker
What should I do?
Username: Soccer
Post Number: 303
What kind of plug?
Post Number: 11
The 1/4 inch plug type
Username: Soccer
Post Number: 307
That's chinese for me. If the wire has a marked side, use it for reference.
