New member Username: JimmmmNY Post Number: 6 Registered: Aug-04 | To run a Line level approx. 20 feet from a computer to a Stereo/amp: Should/Could i use shielded coax ?, rg6 or rg59 ? Can i use speaker wire ? Will Category 5, 5e, or 6 be O.K ? unshielded/shielded ? * Some of these wire types are already run in the walls to my locations.* But would like to know which one i can utilize (if any) for a connection from a computer 'audio line out' to a stereo amp (or two) /please comment on each of these wire types of you can. Thank You For Your Time . |
Silver Member Username: EdisonGlendale, CA US Post Number: 523 Registered: Dec-03 | Sorry I can't really help you with the cable specifically, but if you really want good sound from your computer, you might want to upgrade the soundcard to something like Yamaha cavit unit. You can get them on the www.amazon.com They do improve the sound. Among the cables you mentioned, I vote for the 5e. They will all work, but you might want to experiment to see which sounds the best. I am getting Belden 1192. http://shop.ebay.com/i.html?_nkw=Belden+Wire+Cable You can also find mogami cable on ebay which should be pretty good - even better than 5e. Try to get thick ones - since it's long - will sound better. Perhaps if you do get a Yamaha cavit, you can make a long usb cable - that might give you a better sound. Another option is to get this philips mini - has usb connection and sounds surprisingly good for the money. http://www.amazon.com/exec/obidos/tg/detail/-/B000278KKI You should be able to get pretty good fidelity from your computer - might want to read this thread on www.audiogon.com to get the best sound. http://forum.audiogon.com/cgi-bin/fr.pl?icomp&1&ctg&0&50& Hope this helps, |
