New member Username: Perla4uPost Number: 2 Registered: 12-2003 | My question is that b/w these two which one would be a better option if space is not the main concern... This is an example...(goes with any bookshelf vs floor standing) Bookshelf: B&W 602 s3 (600/pair + speaker stands) floor stand: B&W 603 s3 (1000/pair) If u observe the price diff its $400 but again I need to buy stands (200+ per pair). So its actually 200 or less difference b/w bookshelfs vs floor stands. Does it makes sense to go for floor stands? Would there be a lot of difference b/w sound quality? Should you look at the freq. ranges? Which would produce more bass? Am a newbie to speaker world and would really appreciate your input on this topic. Please drop your opinion here. Thanks |
New member Username: EdisonPost Number: 33 Registered: 12-2003 | The floor stander has more bass, but I prefer the sound of 602. You might want to consider this $1000 speaker for half off - it sounds more refined than the 602. http://www.audioadvisor.com/store/productdetail.asp?sku=ENERV2.1C |
