New member Username: GalPost Number: 2 Registered: 12-2003 | Any Input will help Cheers |
New member Username: SgtpeperPost Number: 5 Registered: 12-2003 | Just for your info... The dahlquist under that name is not the original high quality dahlquist of years ago. It is the name but not the same company. The real dahlquist was taken over by regner and he makes awesome speakers in the 10k range i believe it is... http://www.regnar.com/ The website isnt very good but his products are! |
New member Username: MichaelslbPost Number: 4 Registered: 12-2003 | Yes! I own and am familiar with the Dahlquists... VERY good speakers, especially for the money. The imaging and clean, tight bass response on these speakers is especially noteworthy. My current system consists of QX8's, QX6's, a QX60C center and a Paradigm PW-2200 sub. Trust me, this system rocks and I've heard that these speakers consistently WIN a/b split tests against Axioms of similar price (but usually a little pricier), which are highly regarded speakers. Here's a couple of reviews for you to check out: http://www.soundstage.com/revequip/dahlquist_qx6.htm http://www.hometheatersound.com/equipment/dahlquistaudio_system4.htm You may also want to do a search for Dalquist on this and other forums, especially Home Theater Forum where you'll find a ton of happy (ecstatic) owners and some rave reviews. IMHO, these speakers are very hard to beat for the amazing value they present. And even better, these speakers are being blown out by several retailers to make way for their new line up (which is very similar except for a few cosmetic changes mostly). You should be able to get a really good deal on a set of these if you're looking. I would suggest contacting Marc H at http://www.audioshop.on.ca and he can set you up with a great set of speakers for a killer price with this latest blow out sale. In fact, I've helped a few others make the leap to go with Dahlquists, and they've all been extremely pleased with their decision. Good luck, and if you have any more questions - just ask! Michael |
