In a 6.1 set-up, you need 3 surrounds...well, duh. But they only sell bookshelf speakers as a set of two. What should I use for the rear? A small center channel? I like Polk...
the ideal would be one just like the rear surrounds..but if u can't find one or someone to split a piar with (that is what i did ;)) then a small center channal of the same type would work great
