New member Username: AvdudePost Number: 1 Registered: 12-2003 | Would an Infinity 'Entra TWO' be a good center to mate with my 'Overture 2' front speakers? There are also two other Infinity centers available: the Infinity IL-36C and Infinity Alpha 37C, which are about 2 1/2 to 3 times as much ($250 - $300 vs. $100 for a mfr refurbished Infinity 'Entra TWO'). Not sure if the difference would be very noticeable or worth the substantially higher price? Are there are other brands' center channels that would be a good match for my Infinity 'Overture 2' front speakers? PS: Does anyone know why html tags (e.g. [b]text[/b] don't seem to work?) Thanks! |
New member Username: AvdudePost Number: 2 Registered: 12-2003 | I guess the 'Overture 1' would be better, even though it isn't officially a center channel. If not there is the matched Infinity CC-3. Any thoughts? There must be some people who know about Infinity speakers and matching centers? |
New member Username: AvdudePost Number: 7 Registered: 12-2003 | If anyone has some feedback for a relative newbie to the world of HT, I would appreciate it. Thanks! |
New member Username: UnicronwmdPost Number: 1 Registered: 12-2003 | Sorry man, but most people on this board are too good for Infinity speakers. I have both the Overture-1s and the CC-3 center channel. The Overture-1s are one of the most 3 dimetional speakers I have ever heard. I also have had my CC-3 for about 4-5 years and I love it. It blends very nicely and plays loud but remains very smooth. I say, check ebay for the CC-3 and try to get it for about $150. There really isn't a need for the Overture-cc and the 8" powered woofer.(the Overture-cc is the Overture-1 center channel) Also, the CC-3 has 2 tone controls to help match with other speakers and to be customized to what you want. Hope the helps. WMD |
New member Username: AvdudePost Number: 8 Registered: 12-2003 | Thanks for the reply WMD! Yes, I thought the CC (or Overture 1) might be overkill. I thought I might get a used one for under $200, which would make it worthwhile. I have been looking at the CC-3 auctions already. I got my Elite VSX-43TX last week, and it is a great receiver, especially when found for under $500 new. The center is really the only thing that could use an imminent upgrade in my HT system, which is why I am looking. |
New member Username: HeffPost Number: 10 Registered: 12-2003 | It's a good idea to timbre match your center channel to your fronts for a pleasing front stage. Used speakers or close outs on older models can save you some $$$. Let your ears and wallet be your ultimate guide. |
Auction Link Unregistered guest | http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14992&item=3067353618 |
