AV | hi I need help maching speakers for MF A3.2 integrated amp. my options are: 1. B&W CDM 7NT 2. MONITOR AUDIO GOLD 20 3. MONITOR AUDIO SILVER S8 4. JAMO D870 5. INFINITY KAPPA 400 thanks for any help AV. |
AV Unregistered guest | anyone ??? |
New member Username: EdisonPost Number: 8 Registered: 12-2003 | I like the B&W and Monitor Audio. You might want to hear Tannoy, Paradigm, and PSB. Speakers are subjective, so I would take the amp to a HIFI store and see if they would hook it up for you. I am not being much help in directing you to a particular speaker, but it depends on the type of music you listen to, and it's your toy, so you must be happy with it - not I or any audiophile. Since you are starting with a nice amp, with the right cd player, you should end up with a sweet sounding system - but the final speaker choice should be made after hearing them your self (with your favorite CDs you will be listening to). I would spend about 5% on cables as well. Ixos makes decent affordable ones. http://www.accessories4less.com/Amazing/index.asp?CartId=1-EVEREST-2056319WOSFH4 8&FCat=1&FSCat=++++++42 |
