Amp cutting out
MRSteve
Hi all,
Recently I was given an old Sony TA-F210 amplifier, when it works its great (I have my computer plugged into it). However on occasion it goes pop and wont work for a short time.....any suggestions....
Thanks in advance
Steve
Username: Soccer
Post Number: 258
How do you have it wired?
MRsteve
thanks for your fast response....ok...please bear with me as I know very little about hi-fi etc.....
I have a single jack going from the back of my PC witch splits into two phono(is that the right term?) jacks, these are black and red, going into the VIDEO/AUX sockets.
Also in terms of speakers I have 2 Marantz HD180 speakers rated at (impedance 8 ohms) MAX POWER 40watts.
Also the problem seems random rather than when I turn up the amp(just my opinion as I know sooo little)
Thanks again
Steve
Username: Soccer
Post Number: 260
I don't know what kind of sound plate you have installed on the pc, but you could be plugging the 3.5mm jack to the phones output of the plate; try reducing the output level at the pc and check if it fixes the prob. If not, did you made the cable yourself? You could then be having bad contacts either on the 3.5 mm jack or on the phones jacks. Or the sound plate doesn't reliable plugs which originate some bad contacts. You only get this prob with that input (AUX)?
MRsteve
turning the pc volume down, seems to have worked...thanks ever so much....couldnt aford some new kit and couldnt bare to go back to those little tinny PC speakers .......Thankyou...thankyou...
Steve
Username: Soccer
Post Number: 266
We are all here to help each other, you could help me some other day!
Enjoy!
MRsteve
roger that.......and i'd love to help if ever I could......... steve@minki.co.uk
MRsteve
Hi there,
Its I again, ok after a while the problem reappears, also i bought new cable to check and same problem, where would you suggest I look to next,
Once again thanks for all your help, also could this be a form of thermal cut out?
Steve
Username: Soccer
Post Number: 295
You should have another line output from your plate on the pc. Ty that and get back
MRsteve
hi there plugged into the 2nd output on PC but no output? Are there any settings that could have disabled it? Its definately an output, all I have is 2 outputs and one mic in (avance ac97 onboard sound).....
Thanks as always
Steve
Username: Soccer
Post Number: 304
Star-Definitions-Control Panel-Sounds. Check these definitions.
Username: Soccer
Post Number: 305
Sorry, I forgot to ask which operating system?
MRsteve
its win2000 pro
MRsteve
set up is Desktop Stereo Speakers
thks
Username: Soccer
Post Number: 306
Ok, but open it and choose options-properties, and check which outputs are active
my sony xplode (760watts) cuts out when i turn it up over half way.i have 2 10in jl audio speakers (subs) in box. oh i have to turn head unit off to reset and it works again
i have a 1995 nissan pathfinder it has built in (2) amps 8 speakers (4 tweeters) i replaced head unit and it had to much wattage so i had to buy this $70.00 watt limit thing now my sound is thin as headphones (not on your head ) blasting, do i have to run the wire to and from unit to speakers or could you tell me what i could do please HELP!!!
Username: Soccer
Post Number: 309
You'll get a better answer in the car audio section
