Best 5.1 speaker system for $1000 - $1500?
I Need Speakers
I'd prefer to stay away from 'Speakers in a Box' set, but for this range I might have no choice. I have the Harman Kardon 7200. Thanks in advance
Username: Levike
Cathedral City, California USA
Post Number: 13
Hi, Since you have the Harman Kardon 7200 I would recommend Definitive Technology Speakers.
They have one speakers in a box with 4 speakers, a center and a subwoofer.
go to www.definitivetechnology.com and check it out, I believe it costs around $650 to $1000, and I know those would work perfectly with HK, because I used to have Harman Kardon with Def Tech speakers. You will not find a better speaker for home theater for around this price range.
Hope this help!
Good Luck
