Speakers
I have speakers outside. How, on the Yamaha RXV1000, Do I shut the speakers off inside but leave them on outside. MY AB switch works for the outdoor ones but doesnt' shut off the indoor ones.? Should I just plug in a headset?
J. Vigne
Mary, I don't know that reciever. You may need an outboard switch box. I'd look through my owner's manual and if you don't find your answer there then you should call your dealer. They should know the answer to your question.
