I just bought this great receiver a week ago. I have had only 1 problem thus far. The "learning" function on the remote does not work. When I follow the instruction manual and get to the 2nd step, the send/learn light never comes on after releasing the Mode and Enter buttons. Took it back to HH Gregg and tried another remote. Same problem. Checked 2 open box remotes. No luck with them either. This is not "user error" either. We had 3 people trying to get it to work to no avail. Anyone else had problems with this? Also, what is the best alternative for connecting speaker wire to this receiver if I don't want to use bare wire (in order to prevent oxidation)?
SMess
Anybody?
Sorry, I have the 600 but didn't use learning function. I have an all in one remote to use.
Unless you are going to be changing wires around, bare wire is fine. Spade connectors, etc are all for convenience.
