Reciever and parasound poweramp
Username: Philly
i purchased a denon 5800 awhile back, i also have klipsch rf-7 loudspeakers hooked up. I wanted to get more power out of the speakers so i decided to add a parasound hct1500 amp. is this gonna make my speakers louder? the speakers are rated 250w-1000w? thanks
Username: Edison
Glendale, CA US
Post Number: 476
Try it out at home, and see if you like what you hear - you will get some improvement - but you are still using denon which is not as good as parasound for pre-amp, so you wouldn't be getting the most of what the parasound has to offer.
If you really want good sound, you need to have a good pre as well.
It will give you some improvement for sure - just decide if it's enough for the price of para.
You can get a used one on www.audiogon.com or the ebay. Audiogon is more respectable and trust-worthy. Be careful on ebay - make sure the seller has many good ratings.
I like parasound sound - I have their CD player and I too am gonna get one of thier amp one of these days.
Username: Philly
thanks for the reply. so now what do i do with the denon.? i figured that i probably needed the pre amp also. when i went to the audio store seemed like the power using the amp/preamp blew away the the a/v reciever.where you had to only turn the volume control on the preamp to 2-3 where is you had to keep turning the volume on the a/v reciever just to gain some power. Being that the denon is 170w/channel and the parasound is 205w/channel. i figured the denon to be quite as powerful and i was told that its not. I dont know how true this is.
Username: Awedio
Montreal, Quebec Canada
Post Number: 15
ill take ur denon off ur hands :-). seeing as u dont need it anymore.
i was checking out the parasound amps....how much do they retail for?
i
