Dual Voltage or 220V Onkyo 601
unregistered
I need help !! I am looking for 110/220 volt dual voltage Onkyo 601 receivers to be more specific. Is there anyone who knows where I can find it? Thanks a lot in advance.
Username: Geekboy
Newport, RI United States
Post Number: 313
unregisterd: Just to to http://www.onkyo.com and select downloads. Go the the section for Manuals for Receivers. Select the TX-SR601 manual. Page 7 shows you how to set the switch for 230/220V or 120V operation.
The models which have this feature are the SR601 and SR601E. Is that what you're looking for?
Unregistered
Thanks a lot, That is exactly what I was looking for.
