Speaker hookup
misterman
I just got a Bose acoustiman 7 series which has three double cubes and a subwoofer.
I want to hook it up to a Sony STR-D1011 receiver.
The problem is that there are three speakers (each go to the base module) and then three wires are supposed to go the receiver. The receiver only has 2 front connections!!
It has 2 center, and 2 rear as well, but the sound is very weak from them and the speaker is ment to be a front!
Any help/advice?
Username: Edison
Glendale, CA US
Post Number: 472
I would try to connect the 3rd one to the center - and you should be able to adjust the volume to your liking.
