Connecting A7N8X-E Deluxe Audio to a Pioneer VSX-D710S Receiver
deza992450
I have an AMD 3200+ with 1GB Ram and a A7N8X-E Deluxe Motherboard, and I am wanting to know how I can connect the Onboard sound which is SoundStorm / Dolby Digital Audio to a Pioneer VSX-D710S Receiver info can be found here. http://www.pioneerelectronics.com/p...DetailComponent
Thanks.
__________________
Windows XP Professional (5.1, Build 2600)Service Pack 1
XpertVision RADEON 9800 XT (256MB)-(Stock Speeds)
NVIDIA nForce Audio 6.14.0431.0000 (English)
2 x 512MB Corsair Value Select (Running Dual Mode)
AMD Athlon XP 3200+ (Stock Speeds)
3 x 80GB Seagate HDD (7200rpm)
Auriga Case With 350W PSU
ASUS A7N8X-E Delux Mobo
1280 x 1024 (32 bit) (75Hz)
Philips 109B40
DirectX 9.0c
Cataylst 4.9
Username: Landroval
Post Number: 477
You need only one digital cable, probably optical. Just plug the mobos output to the receivers digital input.
Username: Kegger
MICHIGAN
Post Number: 1176
I have seen a lot of m/b's lately that have a coax out.
but the same thing applies that landroval said.
deza992450
Thanks for the replies, but what do I set my receiver to when I have made this connection ?, there are many different settings like DVD, TV/VCR, Tuner etc.........
deza992450
link to receiver was supposed to be 2076_4153_36869_tab=B%2C00.html?compName=PNA_ProductDetailComponent,http://www.p ioneerelectronics.com/pna/product/detail/0,,2076_4153_36869_tab=B,00.html?compNa me=PNA_ProductDetailComponent
Username: Awedio
Montreal, Quebec Canada
Post Number: 13
You have to set your receiver to whatever setting you plugged in your digital cable to. for example, if you plugged it in to aux or cd, then that would be what you choose on the receiver. All the connections are usually labled, and if (as in most cases) the digital inputs are assignable, then assign the one your using to the respective setting on the receiver.
i
deza992450
I am now playing doom 3 through the System, I had to change my settings to VCR/DVR.
