mckenzie Unregistered guest | Hello today i tried hooking up a home audio sub with a built in amp up to my minisysytem. My minisystem has rca inputs. I tried hookin up the sub through that but it did not work. it did work though if i used speaker wire. When i hook it up using speaker wire am i using the amplifier built into the boxes power or the minisystems power. thanks alot |
Gold Member Username: KeggerMICHIGAN Post Number: 1170 Registered: Dec-03 | your using the speaker box power. also you need an rca output from your minisystem not an input. |
mckenzie Unregistered guest | well all i no is i have the red and white plugins on my mini system and the amplifier. so your saying if i use speaker wire from my minisystem to the amplifiers im using the plate amplifiers power not the minisystems. thanks alot |
Unregistered guest | i am interested in making all of my boxes powered units , but i have very little knowledge of sites where i can find these units, especially high powered, high quality ones for sale. any help or information will be greatly appreciated |
Bronze Member Username: NatediggidyBaltimore, Maryland U.S.A. Post Number: 45 Registered: May-04 | Is this what you need? http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=43&Object Group_ID=505 |
