I need some help BIG time
Username: Xxmr_bacardlxx
Buda, Texas Usa
i need help ive got an amp but dont know anything on hooking it up can someone help me
Username: Awedio
Montreal, Quebec Canada
Post Number: 11
Well to start...do u have an integrated amp? is it seperate with a preamp? or is the preamp an av receiver? how many speakers? basically all u normally need to do is plug in ur speakers to ur amp and the amp into a preamp. from ur preamp/receiver all u need is an analog connection to ur amp.
i
Username: Kegger
MICHIGAN
Post Number: 1154
yah like ian said much more info is needed to even start to help you.
Buda, Texas Usa
really what i need to now is how to hook it up to the car i think i can get the speakers connected
Buda, Texas Usa
like how do i get power to the amp and do i connect the amp to the head unit or were is the best place to connect it
Username: Kegger
MICHIGAN
Post Number: 1171
your better off asking this question in car audio.
your ib home audio/amps.
much more educated auto guys over their.
Username: Peety
I have a Orion 2100HCCA series amp.I'm having some problem getting it powered up.Do anyone know where I might be able to get a schematic or assist me trouleshooting the problem?
Username: Project6
Post Number: 1460
yes...the Car Aduio forum, this is home audio!
Username: Project6
Post Number: 1461
yes...the Car Audio forum, this is home audio!
Username: Bigrich0086
i have a sonyxplode amp 4 ch. i turn on the ignition on and my ground wire is connected and the power wire is connected my 3 green lights com on. but the equalizer on the amp that moves with the music wont work neither will my subs. will that be caused by a bad remote wire not sending the signal form the radio to the amp then to speakers. PLEASE HELP ME ASAP.
Username: Unbridled_id
ChicagoUsa
Post Number: 48
c...a.....r... a.....u.....d.......i......o
f.....o.....r.....u.......m.....
Username: Project6
Post Number: 1463
Wow, do you guys even read anything before posting?
