Amps
Username: Bonyfinger
have purchased a pre/pro RotelRSP 1066-used and need a decent amp to go with it. any suggestions that won't break me.
My brain expelled some gas and I thought I knew what I was doing. It wasn't till after the auction that someone told me I needed an amp to make ther thing work
Username: Kegger
MICHIGAN
Post Number: 1142
i have looked at that prepro myself.
and was looking at parasound amps. also b&k.
and i was also looking at adcom. you can find
all of them used or good prices new.
there is many way's you could try amps on there.
you could go with a 5channel amp and use it like that.
you could go 2ch and 3ch
2ch and 5ch
3ch and 4ch
5ch
7ch
also nad and marrantz make some quality amps for the money.
yah unfortunately you do need to spend some more cash to use that thing.
if you didn't get it from audiogon and you don't
know about them. try audiogon.com for used.
