Bsx Unregistered guest | I'm currently restoring two old (at least ten years old) home speaker boxes (they stand upright rectangularily with two 3" tweeters). I've removed all the speakers and I am planning on buying two new 12" subs and 4 new tweeters. I happen to have an old 300 watt car amp lying around and was wondering if I should simply buy a new home amp, or would it be cheaper to use the car amp for power? If it would be cheaper to use the car amp, exactly how do I connect it to the home electricity, and also, should I buy car subs or home subs? |
Gold Member Username: KeggerMICHIGAN Post Number: 1133 Registered: Dec-03 | my oppinion would be get a new home amp. the power supply you need to drive a car amp in the house can get pretty expensive. in a car the amp uses your electrical system to power it and some times you need a better charging system and larger battery to get that done. just my 2 cents you can do it but i think you'd be better off with a qualty home amp. |
Bronze Member Username: FryguyBarrington Passage, Nova Scotia Canada Post Number: 35 Registered: Jun-04 | check out ftp://fryguy.ca/Public_Files/Guides-Information/Hacks-Mods/ the document is called "Using an ATX computer power supply to make a scalable multipurpose power supply.doc" hope this helps. |
