Which hookup is best for Receiver
Username: Bbruins2
Post Number: 22
Which sub hookup would use the subwoofer power & be less of a strain on the receiver.I am now using the rca hookup but I thought my previous speaker wire hookup had more punch.Does this make any sense?I am using a HK 330 receiver with a CV lw15 sub.The sub does not seem to be as powerful now with the rca (with Y)hookup.Maybe I've got all my settings screwed up.Please help.Mike.
Username: Arnold_layne
MadridSpain
Post Number: 64
Receiver specs are sometimes misleading. Watts are indicated as maximum for one channel working alone. A different story when all channels work together. Then power supply becomes an issue. If you're a fan of high volumes, it could be a good idea to check out your receiver's maximum power consumption, divided by channels used.
Cheers
AL
Username: Bbruins2
Post Number: 23
This doesn't answer my question.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 42
The sub is self-powered anyway, so either should be identical. The gain might be different, meaning you have to turn the sub's level dial to different settings for both hookup methods.
Peter
Can you hook up a car sub to am av reciever and would it still sound good?
Can you hook up a car sub to an av reciever and would it still sound good?
