Using cheap rear surrounds?
Username: Diplotocus
Post Number: 20
I have a set of LSi9 fronts (VERY nice bookshelf speaker for the $$$), an LSiC center chanel, and a PSW505 sub. I really don't want to shell out another $900 for a second pair of LS19's for the reas surrounds, and I don't even want to shell out $700 for a set of LSi7's, which are currently the *only* voice matched speakers that Pols makes. If I buy a "cheap" set of rear surround speakers will it "ruin" my nice front setup? Thanks for any advice.
Username: Edison
Glendale, CA US
Post Number: 446
Not much is going on there, so you might want to buy used paradigm titan speakers from www.audiogon.com or the www.ebay.com Even the new titans are only $200
I would also get Ixos cables (gamma technology) from www.accessories4less.com to get the best out of your speakers. Your speakers will sound their best with better cables - that is if you don't have good cables already.
