I'm debating on buying 1 velodyne cht-12 or 2 chy-10's for a large room. Recommendations. And if I get 2 cht-10's how do you hook them up. Can I run speaker levels L&R to sub1 and continue from speaker input on one to speaker input on the second sub???
getting two subs helps increase the overall sound and spls coming from your system. two is always better than one. their are many different ways u can do this. one way is to use the speaker levels. connect your fronts to one sub and your rear speakers to the other sub. or u can buy a Y splitter. i have heard of people using a Y splitter and connecting one to one sub and another to another sub. this is how u would do this. connect the Y splitter to the receivers sub out. and then buy two subwoofer cable. the cable make all the difference in the world i think. then connect each sub cable to a different subwoofer.
