Paradigm Studio 20s or NHT SB3 with Denon?
tosha
Does anyone know what might be a better match with my Denon receiver? It is 80% music (classic rock/jazz/etc.) and 20% movies in a small/medium room.
I'm just concern that the NHT might be too bright with Denon, but I'm not sure. I can't buy both to compare them.
Thank you.
duddly
I say the Paradigm Studio 20s
Username: Jamesp
Mansfield , TX USA
Post Number: 12
I listened to the NHT SB3's on a Sony ES and they did not sound bright to me. They are great sounding speakers but I preferred the studio 20's which I went with.
Username: Elitefan1
Post Number: 546
With Denon the Studio 20 is the better choice. A warmer, fuller sounding speaker goes best with the Denon thin, detailed sound. Which Denon do you have. I had a 2802[liked it] and a 3803[really,really hated it].
Thank you for everybody's comments/suggestions. I was lucky enough to borrow my mate's NHT SB3, brought it in the store (couldn't bring home the Studio 20s), and did a comparison with the Studio 20s. It was matched up with Denon 3805.
I like the sound of the Studio 20s when it came to music. Since, my mix is 80%music 20%movies, I decided on the Paradigm Studio 20s.
As for upgrading the receiver, I'm pretty happy with my Denon 1804 for now so I might use the $$ for stands/rack.
Once again, thank you for everybody's comments.
