CA azur 54R Vs Marantz SR6400
lape
wich one would you pick?
-540R (built after april 23rd) or
-SR6400
Username: Falp
Post Number: 45
Thinking about price it would SR4400 vs CA540R...
endora
It depends where you live. For example in France, the price equivalement of the 540R is the Marantz 5400 OSE.
It seems that they are both quite good in hifi which is not very common for a HC receiver. But they sound very different depending on which speakers you have, so it would be best to listen to both of them on your speakers before making a decision.
lape
here in Canada
azur540R = 950$
sr6400 = 1000$
Username: Valeem
Post Number: 136
Here in the UK the equivalent to the SR6400 is the 5400 OSE and that can be had for £378 online (MRSP of £550) and the 540R is available for £250 (same as from the off). A not insignificant difference. Generally though the 4400 is considered the equivalent to the 540R in price and possibly performance terms.
Username: Falp
Post Number: 46
Both have a major drawback, Fixed Xover frequencies.
CA540r - 80Hz
SR4400 - 100Hz
Prices in portugal:
CA540R - 528€
SR440 - 519€
SR5400 - 799€
SR5400OSE - 1199€
SR6500 - doesn't exist
Great machine the sr5400! Go for it or wait for the Sr5500 (september)
Username: Valeem
Post Number: 138
Agree with Falp about the Marantz 4400 LFE crossover setting. I would like to have used one at 80Hz. I'm not entirely convinced 100Hz is ideal for a sub.
Username: Falp
Post Number: 47
I would even put my to something like 40, 50 or 60...
But better to be variable.
Username: Landroval
Post Number: 450
SR5400 and above do have adjustable sub x-over.
I would take the 5400OSE over the 540R, but I dont know if the 6400 is as good as the OSE. The Marantz have more features but the 540R is nice and simple with good sound.
