Technics 590 vs Nad 521 CD
Username: Alexsoftwareltd
Hi,
I own CD Technics SL-PG 590 and NAD C 350 + KEF CODA 7 speakers.
I want to replace Technics SL-PG 590 with NAD 521 CD. Can I expect any improvments in the sound.
Thankful in advance
Username: Edison
Glendale, CA US
Post Number: 432
Yes you can - but I am getting Shanling CD-S 100 which is said to be even better than NAD 541.
NAD 521 will be an improvement, but there are even better ones for a little more money - and you will be able to hear more of an improvement - smoother sounding that is so pleasant.
Thank you for this.
Which are your recomendetions?
Username: Edison
Glendale, CA US
Post Number: 438
Parasound makes decent ones - check www.audiogon.com for used one if you don't want to pay a lot.
The sound will be smoother and deeper - without the shrill sound of Technics.
Thank you,
I bought NAD 521i and I'm very satisfied.
