New member Username: DrpjePost Number: 3 Registered: Jun-04 | Has anyone had any experience with the Denon PMA 2000 IVR Integrated amp. I plan to use the amp with a pair of the B&W 704 speakers and the Denon 2900 DVD player. Any other options to consider. Thanks |
Silver Member Username: EdisonGlendale, CA US Post Number: 418 Registered: Dec-03 | Your speakers will perform better with better gears. Post it on www.audiogon.com, and you will get helpful responses. You can also buy used gears there - good deals. This way, you will end up with a more satisfying system. |
