Is there anyway to hook a Pioneer 2 channel bridgeable power amplifer to a home stereo system?
Username: Leighton
Chilhowie, Va USA
If there is a way to do this please tell me and give me a full step instructions on how to do this.
Thankyou
J. Vigne
If it is possible, and we can't tell you from out here with the information you have provided, it will tell you how in your owner's manual. I would start by reading it.
Username: Leighton
Chilhowie, Va USA
Well I would read the manual but the amp was given to me by a friend and I did not get a manual with it so can someone please help me
J. Vigne
not with the information you have provided. You have to tell us more.
ABC
what do you want to hook it up to
yes u can actually hook it up dont listen to them but u have to get a converter or use a straight car battery in ur house ive done it
Username: Gargoyle
Leicester, England England
i need some help, i have a amp running my 1000 wat rms sub. i going to by some tweeters,componants , and 6x9's and to run all this a 4 channle amp how do i hock this all up
can i take feeds from the 12v , RMT , GND in to the new amp and get a spliter for the rca's???
my pioneer head unit only has 1 set of rca's wat do i do ?????????????????????????
