Boston Acoustics A120
Username: Cubancorona
Charlottesville, VA USA
The foam around the 10" cone finally broke off. Is there any way I can replace it? I love these speakers and would hate to lose them because of this.
Also, I'm very interested in audio/speaker theory, but I don't know where to get started. Can anyone recommend some good links/tutorials?
Thanks!
j. Vigne
Just put something like speaker surround recone into a search engine and you will find someone to send you the kits to redo the surrounds. you can also check with shops that do pro audio/sound reinforcement for someone in your area to do the repair.
Start with "definitions and descriptions" under this site on the forum.
https://www.ecoustics.com/electronics/forum/home-audio/56618.html
