Yes. There are many ways you can do this, but the easiest I've found so far is by using Flash. Make a sound object in flash, and have it stream, and automatically play. You can also do it with Realmedia, but I've found mp3+flash to be the easiest method so far. Check some Flash forums for help if you need it.
