Pioneer Elite 53TX
HelpTed
I have 5 speakers + a sub. I have everything connected but I am not sure what to connect the surrounds to? Since it is a 6.1/7.1 Amp there are SIDE and REAR connections for the speakers.
Which one do I use?
G.DawG
Connect them to the SR and SL(I am pretty sure thats what the labels say, as thats what the lables say on my 43) the SBL and SBR are the surround-back channels.
G.DawG
G.DawG
Ted,
There is a diagram in the manual, am I right?
Did you buy a new one? if so, it should come with a manual.
G
HelpTed
I bought it new and have the manual. The only picture it has shows only the full blown setup with both surround left, right and rear left right.
I will connect it to the sl/sr and see what happens.
Thanks
