Questions about my amp
pimpinindtown
my amp is always on even if the car is off. will yhis cause a problem? and my amp always overheats and shuts off after about 20 minutes depending on if its hot out(overheats quicker) or cold.
Username: Kegger
MICHIGAN
Post Number: 922
try the car audio section instead of home audio
and you may get better luck with an awnser.
