NAD display and fan question
Username: Mfriend262
Hi all-
I just picked up a NAD t753 to drive some maggies that i recently rebuilt. It was cheap but has 2 issues. The display on the receiver doesn't come on (though the on screen display works) and I am getting some fan noise. For the fan the noise is indicative bearing noise. It is not too bad but i am worried about eventual failure. Does anyone know where to get a replacement fan? For the display, i tried the various reset button pushes but it still doesn't come on. Are there any reasonable fixes?
Thanks!
Username: Magfan
Post Number: 3660
DIGIKEY would be where I'd start, after NAD told me they had NO IDEA.
Than? IF you can easily remove the existing fan? See about measureing its voltage....with an eye towards replacing.
take some basic measurments.....hole spacing, size / LWH .....that sort of thing.....
Need to Register?
Forgot Password?
Enable HTML code in message
