CD Player Compatible With AirPods
Username: Al_sharp
Can anyone tell me if they know of a reliable CD player, either portable or a small boombox, that is compatible with my Bluetooth wireless Apple AirPods? If I am not mistaken, and I may be, it would need to be Bluetooth transmissible. Every CD player I have looked at is only Bluetooth receivable.
Any help or guidance sure would be appreciated!
Thanks a lot,
Al
Username: Rareskyfive
MinneapolisMauritius
Put on your Bluetooth headphones, make sure they are paired to the Oasis, and you'll now hear your CD through the wireless headphones. You can control the volume using the buttons on your headphones.
Need to Register?
Forgot Password?
Enable HTML code in message
