Philips GA222 - replaced power switch and platter spins at warp speed
Username: Ramjaccorp
I followed a tip I found online for replacing the poorly-designed original power switch with one from a computer. The two power leads went to the top terminals, the brown lead to the bottom left, and the blue to the bottom right. The new switch worked perfectly, but when I start her up, the platter spins like a washer on spin cycle. Anyone have any ideas how I might troubleshoot this? I don't even know where to start. The turntable has been in storage for decades, but it worked perfectly when I stored it. It was, unfortunately in an attic that gets hot, so I'm thinking something might have been affected by the heat.
Need to Register?
Forgot Password?
Enable HTML code in message
