Onkyo TX-8511 fuse blow - where to fix?
Username: Altmanaj2018
New York, New York United States
The receiver is turned on but no sound comes out thru speakers or headphones (it worked last week). I recall years ago that when I changed a fuse that did fix the problem. I found a package of (old) Radio Shack 4amp fast acting fuses - 250 volt - 3AG or AGC-Type - so this must be what I used. The problem: when I take the cover off the receiver now (unscrew 5 screws) I don't see a place where the fuse would go. (I do see one other fuse but it is shorter.) I downloaded the service manual but I don't understand it.
Help is welcome!!
Username: Jan_b_vigne
Dallas, TX
Post Number: 18627
Most modern receivers discourage owner involvement in repairs, even those as simple as replacing a fuse. I can't tell you the location of the fuse, if they are accessible or not. Schematics don't show the physical layout of the receiver, simply the signal flow and circuit breakdown. Fuses are typically located at the rear of the receiver between the entrance of the power cable and the main power transformer. 3AG's would be 3 Amp fuses.
If you can't locate the fuse holder, best advice is to contact Onkyo.
Thanks for your response
Username: Magfan
Post Number: 3521
It would seem that Rear Panel fuses are GONE forever. Probably caused more problems then it was worth.
Boneheads would figure that if the '5 amp fuse blows, maybe this 20 will work better!'
Need to Register?
Forgot Password?
Enable HTML code in message
