Suggest RCA to Banana Plug Converter
Username: Renaestanley07
Fort Walton Beach, Florida US
Hi, I want the suggestion on RCA to Banana plugs convertor. A few days ago I cleaned my storeroom where I get the old woofer system which has RCA slots inbuilt. But, the problem is my speakers have banana plug slots. So what should I do for connecting speaker to woofer system?
Username: Jan_b_vigne
Dallas, TX
Post Number: 18542
RCA's generally mean you have a line level connection while banana plugs would be used for a speaker level connection. You need to determine what the Voltage level is for this connection before you start making jerry rigs.
Username: Project6
Post Number: 16286
Is your woofer system powered?
Need to Register?
Forgot Password?
Enable HTML code in message
