Best monoblock to with centre speaker
Username: Markyboy156
hi
i want to try this instead
in addition to my setup above
i want to add a very good monoblock to the centre speaker to enhance it greatly
i will be using my marantz as main amp
then i will use the music fidelity m3i and crown 102
for the high and low frequncies then to the marantz
to my dali speakers
will connect my blue node2 to the amplifier
my question is i have enhanced my two front speakers but i want to enhance my centre speakers as
well the dali zenor vokal centre
what do you recommend as a monoblock for the centre
same as youve got
or something else you would recommend
i am using dali instead of the kefs you use to take into consideration
also i want to enhance the audio quality of the sony ux800 4k player
by using a arcam ir dac to enhance the 2 channel music of the sony ux800
can all this all be wired up to the marantz amp
Username: Jan_b_vigne
Dallas, TX
Post Number: 18489
There's no way to advise you on a monoblock, your system is, IMO, too haphazard and I have no idea what you think you actually want other than "more".
Rather than spend money on another amp, have you invested anything in room treatments? Up to 90% of what you hear, and don't hear, can be attributed to the room overriding the system. You listen to the room, not the system.
Need to Register?
Forgot Password?
Enable HTML code in message
