Replacement tweeter needed... help!
Nate Raymond
I have an RA Labs (RDL Acoustics) center channel speaker, and from what I can tell the tweeter is blown on it. RA Labs/RDL is long out of business, but from what I've gathered, they used fairly standard OEM parts.
The tweeter is a 1" (25mm) copolymer design, with a rectangular plastic mount. Here are the specs on the center channel speaker as a whole:
Low Frequency Response --
-3dB at 55 Hz
-8dB at 39 Hz
Crossover Frequency -- 3 kHz
Impedance -- 6 ohms
Sensitivity -- 89 dB SPL
Amplifier Power -- 15 to 100 Watts
Dimensions -- 7" x 20½" x6½"
(178 mm x 521 mm x 165 mm)
Weight -- 10 pounds each ( 4.5 kg)
I don't know too many places to get a tweeter from, but partsexpress seems to have a few that might work. This one looks almost identical to the RA Labs tweeter, though it's stats are different than the RA Labs speaker as a whole:
http://www.partsexpress.com/pe/showdetl.cfm?&Product_ID=7349&DID=7
I'm not sure if this would physically fit or not, but the specs seem closer:
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=270-160
How close do the specifications of the tweeter need to be to match the speaker as a whole? Are those good tweeters? Where else can I get a tweeter?
Any help greatly appreciated!
