Help with speakers
Username: Something_
I am a member of a Volunteer Fire Company we need to connect 3 speakers to the radio in the fire hall. The radio accepts a jack (http://www.showmecables.com/images/catalog/product/3-5mm-Mono-Plug-Connector-Me tal-2.jpg) into the itself. We currently have 1 speaker plugged into the radio in the radio room. I want to know the best and cheapest way to connect 2 speakers (https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcRBTPp2pBZuk9FXB0yoGE-0fWQ T7B4e9c6nPHie4wzrCs34W6gZjg) with the 1 speaker still in the radio room. 1 in each bay (we will then have 3 in total) so we can hear the radio when we put on our gear, and when we are trying to start our trucks.
Username: Jan_b_vigne
Dallas, TX
Post Number: 18391
Your first link doesn't work. Your second link provides no more than a frontal view of the speakers, which is rather worthless since I need specs for the system.
You don't say what radio you are using and that is rather crucial since the amp must drive three speakers.
Without any more information than you've provided, I would say try a series/parallel connection; https://www.google.com/search?q=speries%2Fparallel+speaker+connection&rlz=1CAACA J_enUS705US705&oq=speries%2Fparallel+speaker+connection&aqs=chrome..69i57j69i58. 10861j0j1&sourceid=chrome&ie=UTF-8#q=series/parallel+speaker+connection&*
That will provide a lower than normal impedance load which your amp must deal with. If the radio is not overheating when in use, it will likely survive.
That's the cheapest way.
One issue with a series/parallel connection is, should one speaker fail, all speakers will be effected and will not work.
Better is to buy a small switch box with a built in load resistor which provides a bit of "protection" for the amp; https://www.crutchfield.com/p_190SS4/Niles-SS-4.html
That's about all I can do given the lack of information provided.
Username: Edison
Glendale, CA US
Post Number: 969
Are you trying to stream music or what would you be using it for?
Please give us more info...
Need to Register?
Forgot Password?
Enable HTML code in message
