I have the above receiver connected to a Sony TV, inputs are a Scientific Atlanta PVR and a PS3. We recently moved so I unhooked and re-hooked it all up... I find now that on booting up to Watch TV (using a Logitech all-in-one remote) there is no sound from the PVR, but picture is fine.
If I switch inputs on the receiver a few times, the sounds comes through fine. The very first time I hooked it up, there were no issues.
I feel like this happened for a while at the old house, but I can't for the life of me remember what I did about it. Any ideas?! Thanks!
No, physically I didn't change a thing, I mean I switched inputs e.g. from Cable/TV to DVD then back on the receiver... the cables are all and always were in the right places and don't need to be labeled. This is why I'm scratching my head, doesn't add up.
I really can't help without knowing the receiver and your specific set up. AV receivers are fairly complicated as far as signal loops and it's not as easy as a stereo receiver's tape monitor loop.
When I would install an AV system, I spent some time trying to offer options to each owner. It's not uncommon for a AV receiver/system to be wired in several distinct ways yet still work perfectly as long as it makes sense to the user.
I doubt there's anything wrong with the receiver. If there is, it will have to become far more obvious since a tech can't fix some thing that's working.
If you're certain everything is in its correct port or jack, I would make some notes regarding how you get sound and picture. Otherwise, if it's working, that's all that matters.
