I am already set with my own dac/amp and headphones ,I guess all I need is a laser reader receiver [dsp is its technical name ??] CDM0 and CDM1 is the best laser reader ??had many problems in the past with many systems when playing high freq for a longer period ,' it begins to come out kind of crackles and rough, raspy, o breathy. hoarse until it totally stops to sound at all "
that above
accompanied with its right and good power supply ;
If you are referring to th Philips stuff, yes, it is pretty darn good. If you find them, buy plenty of 'spares' while you are at it. Philips is OUT of the market, as near as I can tell.
Others STILL in the market include Sanyo and Sony. Cambridge Audio, for example uses the SAME Sanyo mechanism in its players from the entry level 350 series to the top-line (at about 1900$) 850 series.
When you get a bread-boarded prototype working, post a pic
