Integrated amps
Username: August_g
Jakarta, Indonesia, Indonesia Indonesia
Hi all,
I'm newbie in this forum.
Would like to have suggestion, which one the right choice if I will buy the new integrated amp as follow :
- Naim XS
- Rega Elicit R
- Musical Fidelity M6 or M6si
I need the solid state integrated amp that can drive my existing speakers, Vienna Acoustic Mozart Grand SE, 4 ohm impedance, 90 dB/watt/m.
I also consider to use turntable in the future, so the amps must has phono input connection. I want to listen Naim XS2 but it is still unavailable here in Indonesia. My budget is around USD 200-2500. Other brand is also open for consideration
Looking fwd your advise, thanks
Need to Register?
Forgot Password?
Enable HTML code in message
