Can Naim amplifiers be used as separate mono blocks?
Username: Veinsfractalsyy
Hi im new here, and new to this. I was wondering if Naim power amplifiers could be used as seperate monoblock amplifiers? I cant find this information anywhere. Mainly the NAP 300.
Username: Jan_b_vigne
Dallas, TX
Post Number: 17943
There's nothing in their literature or specs which would indicate against using them as monoblocks. Though some stereo amps perform better when their outputs are connected in series and some when connected in parallel.
Probably best if you ask here; http://forums.naimaudio.com/topic/nap-300
I don't know the amp well enough to give a best case answer.
Username: Magfan
Post Number: 3168
Instead of bridging, any chance of biamping?
