New member Username: Cornelius1Grosse pointe park, Michigan United States Post Number: 1 Registered: Aug-14 | Hi im cornelius, I have water speakers and a amp i would like to know if there is a way i can connect them so i can plug on aux cord into a computer or iphone and it will play through both, is this possible? if so how? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 17934 Registered: May-04 | . I don't know what "water speakers" are. |
Gold Member Username: MagfanUSA Post Number: 3159 Registered: Oct-07 | Water proof or water resistant? Music for the fish in the pond? |
New member Username: Cornelius1Grosse pointe park, Michigan United States Post Number: 2 Registered: Aug-14 | https://www.google.com/search?q=water+speakers&oq=water+speakers&aqs=chrome..69i 57j69i61j0l4.2434j0j7&sourceid=chrome&es_sm=93&ie=UTF-8#q=water+speakers&tbm=sho p&spd=9683228282257840524 |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 17935 Registered: May-04 | . Apparently the "water speakers" are powered by the USB connection from the source device. So you run a USB cable from the computer to the speakers. If your amp has a USB port, use it from a second USB port on the computer. If there's no USB on the amp, use your headphone output to run to the AUX input of the amp. This seems fairly easy to accomplish. If you run into problems, give the retailer a call or call the speaker's customer assistance line. I doubt your phone has enough outputs to work as a source player however. . } |
Gold Member Username: DakulisSpokane, Washington United States Post Number: 1374 Registered: May-05 | I've got to get me some of those. |
