Integrated stereo Amplifier
Username: Moetapu
Hi, I am a total novice with this Denon PMA-880R amp that was given to me. Can I record from TV to an external hard drive via this amp?
Thanks for your help
Username: Jan_b_vigne
Dallas, TX
Post Number: 17791
How would you make the connections? I'm unaware of the Denon possessing the correct connectors for such an operation.
Username: Moetapu
Thanks for responding jan. I had noticed that there was a recording out selector that has options to cd player, tape deck or other on the front. My thought, rightly or wrongly, was that it should feed straight into a hard drive????
Warren
Dallas, TX
Post Number: 17794
Through what connector? There's no connector which would fit a cable appropriate for a hard drive. Right? USB? No. Firewire? No. Ethernet? No.
What are your other options?
Need to Register?
Forgot Password?
Enable HTML code in message
