Sunfire true sub mii
Username: Hungsolow
Can the anyone tell me if the if the z4 diode is a13v diode and a suitable replacement, on the print from carver site I can't locate it, it isn't the actuall true sub print thank u
Username: Frodo_ballings
Can you describe where that zener is located on the printed circuit ? The schema (recotron home audio) is for a more recent version with inegrated voltage regulators type 7813 7913 iso. zeners.
Username: Hungsolow
looking at a schematic a the carver site.there are 6 zeners on the mk2 z1,z2 and so on the z4 is located by the on/off caps c38 i think do nt have board out right now thanks for your help . the print at carver site is for a nht 500watt down converter there are like 4 zeners and are labled 5v and 13v
Need to Register?
Forgot Password?
Enable HTML code in message
